problem Spike of a Pyramide
  • Thread starter Thread starter Gabry10
Gabry10
hi guys, I'm still writing you because I have some trouble, actually very probably stupid but I swear I've been sneaking in all the ways but I can't get to top the edges of a pyramid.
then to clarify better this is the picture of the drawing
evajypav.webpand I should cut those parts that go out that I highlighted by making lines inside.
I should do this design and the goal is the pyramid below
ma4eragy.webpI tried obviously both with top edges, but it cuts me over the top of the pyramid, and with tip (also because of the lines to have a reference), but it cuts me only perpendicularly, and also changing the ucts I can not make him take the road I want.
Excuse me, but I'm freaking out.
Thank you very much in advance
edit: ah I forgot to say I use autocad 2013
make the bird for three points and use the pull command
Hell it was so simple! Thank you very much, I finally chewed everything and I also discovered the command trancia 3p :d
