This is my process (they could be more direct and simple):apparently the system has not loaded the written part so I repeat it in the answer:
Hello everyone,
I apologize already for any inaccuracies, I will try to be as clear as possible.
Suppose we upload an image and build out of it a geometry in 2d,I increase the copy of this geometry and insert it over the image.
I would like to know if there is a command (or a set of commands) to create the projection of the textures contained in the geometry above the image, in the external geometry (I attach a scheme to facilitate understanding).
I would like this shape to move or rotate within the image and the projection of the textures changed accordingly.
I hope I wasn't too imprecise. . .
Thank you!
