angle quotas with advance steel
  • Thread starter Thread starter GianniM
GianniM
Ciauz!
I'm trying advance steel to figure out at least a little bit how this other program works.
Well, it's not easy to understand. but among the many doubts I would ask you this stuff here.
when I make a table of a single piece, such as a tubular bar, it does not quota the cutting angles. So I tried to add the corner manually. It would work as long as the piece should not be updated. at that point back the quotas from layout without indications on the corners.
Is there a way to ensure that the angles are inserted?
Ciauz!
other self-taught question. :biggrin:
advance steel assigns objects to a "design style" they are to make the layout you need. in all there is angular quotation.
advance steel has a "snap" dedicated to manual quotas called "preferred for manual quotas" you find it at the bottom of the list of snaps you already have. if you disable all those of autocad and quoti with its parametric quotas (they are identical to the methodology of autocad) and use only that snap, these quotas even if manual, are maintained in phase of revision. :cool:
