file c.c. duplicati
  • Thread starter Thread starter GiGa
GiGa
doing some cleaning on the pc, I discovered that inventor c.c. libraries are duplicated (c.c. set as desktop content)... considering that they use more than 5+5gb, it would not be bad to delete a copy.
libraries are in the paths:
c:\programdata\autodesk\inventor 2015\content center\libraries
ec:\users\all users\autodesk\inventor 2015\content center\librariesin inventor 2015 I set "Inventor Desktop Content": c:\programdata\autodesk\inventor 2015\content center\librariesof course I tried to delete first one and then the other copy, but at that point the program in any case loads the empty c.c., as if the search path of the c.c. set in the options is influential. . .
Is it the morning change of a Augustine Monday, or is there a way to fix things?
ps: both copies are not simple links, but they are actually files with total disk space of 5+5gb...
the project file, for components loaded by the c.c., aims at a sub-folder in the work area (comfort to back up the contract)... and I cannot/want to change it.
at this point, saving the 5gb of space becomes almost a secondary problem... I would like to understand why inventor uses two routes for c.c. even if only one is indicated in the options.
