information about filling out separate table base
  • Thread starter Thread starter Petruz
Petruz
I have a problem with compiling the separate table base with proe wf5.
I practically have various assemblies composed by its various parts .prt these parts but have inside it a feature of union inheritance that goes to recall the crude departure.
is it possible to make the information related to the .prt file appear in some way in the separate base, inserted as an inheritance union within another .prt?
normally with what methodology you work in proe to make the information of both the crude and the finite appear in the separate base?
I press that with crudes I mean pieces shaped for the realization of fusions that are subsequently processed.
petruz
you should create parameters in the parts that automatically extract the references of crude models and use the latter to insert them into the separate base
aminati
In these cases, I insert the raw piece into the worked together, without using the function of union inheritance, so doing I have all the data in the distinct base, both of the crude and of the work.
thanks for the advice,
as indicated by dani-3d if I understood well realize the finished as together placing the crude as a assiemated component and then going to remove material, sincerely I had thought also it is only that I find myself in the data base an enormity of files made with the inheritance union and therefore I wanted to find a solution not to remake the finished 3d + put on the table.
as written by aminati you could explain better, as you can tie the crude with parameters so that its data is displayed in the separate base.
Thank you very much
petruz
how it is possible to bind the crude with parameters so that its data is displayed in the separate base.
in order to give you good advice, you should tell us what parameters you want to see in the separate.
you can do so, provided that the feature of union inheritance is of the type "external heritage" in this case you have access to the parameters of the crude you have inserted.
dani-3d I confirm that it's like external inheritance you can tell me how to do it?
Thank you very much
petruz
Well,
go to the part or the working together and enter the relationships
tools > relationships and insert a parameter e.g. weight_grezzo =, then
insert > from list
search in inherited and click on the feature external inheritance
select the parameter that contains the weight of the rough part
Enter selection
repeat operations also for other information and the game is done.
the new parameters you can recall them in the separate.
p.
It's a method I know at the theoretical level, I've never used it in practice, well verify that everything is smooth
great dani-3d six mythical:finger:
seems to work the only parameter that I can't get autoamtic is the amount I go insert it manually in the type report (quantita'=1)
Thank you very much
Good day
petruz
Hello, and thank you for the compliments, always please.
for the automatic quantity, as I suppose, is a problem, because rightly pro-and does not separate the features of union inheritance. if you don't mess with the project, keep the crude through the inheritance union to save the masses in the table and all the rest, and insert the crude as part of the work together.
I had thought about the trick you told me, but it seems to me, in my opinion, a procedure a little messed up and then I would go to uncombustion the total weight of the aid if not that I go to insert a slice of cut that removes all the crude.
I think I'll use the method of relationships.
Thanks again
petruz
Hi, I read that it's been a couple of years after this discussion and I hope it's still available to help the "next". I would like to use I recently create and thanks to iutub, cad3d and network, I solved a good part of the "complications" that the ptc "offers" to its users. place three images representing, the table of origin, revised and 'change symbols'. I have highlighted in that revised, after insertion of 'cilindro_anima' (review case) comparison with the previous one, it is noted in fact that the qtà is accurate while the weights are not updatedimmagine3.webpThank you for reading me.
... and I hope he's still available to help out the next one. ...
certainly
the behavior of the table is a little strange, apparently the fact that it does not update the weight has no explanation.
try to suppress everything that is not cylindrical_soul and see what happens, there might be parts that disturb, I don't think anything else.
if you do not solve try to post files, simplified at most, that I will take a look.
Good Sunday
certainly
try to suppress everything that is not cylinder_anima and see what happens, there may be parts that disturb. . .
the exact result changes with attributes> double...why some parameter in config.pro to set that ignore?doppi.webp
Hello, magma.
I have dealt with your table, I have a doubt, the weight you put in the column weight sand resin is perhaps the unit weight? maybe you do the sum only of the unit weights without multiplying them by quantity? if so you have to create a new column where to insert the individual weights multiplied by the respective quantities and then make the summation of this new column.
Hello, magma.
Okay dani... we're on the right path... the attached image shows the "progress" but I'm not satisfied yet, you will notice that I am obliged to add columns for every total, imagine if I have to insert... .even only 5 types of materials, what mess would it be? the solution at 'mage' I found it with reports in table pesotot=asm_mbr_sabbia_asciutta*rpt_qty and consequently &rpt.rel.pesotot. I tried pesotot=asm_mbr_sabbia_asciutta*rpt_qty+asm_mbr_sabbia_umida*rpt_qty, to get the total total, no error but does not appear the sum in the table.. .relazione.webp
I'm sorry, but I can't figure out the result you want to get with the table, can you do an example, maybe with excell, which then we're going to question?
Okay, all right. to get the totals you have to use the repetitive region function, from a name to the parameter and call it back in the cell you want preceded by &.
