solid conversion part composed surfaces
  • Thread starter Thread starter mdbosca
mdbosca
I just can't convert to solid to speculate the part composed of surfaces. . .
If I do the mirroring makes the mirrored part invisible.
I attach the part so that you can examine and experience conversion in solid.
Thank you!
I do this
- surface area
- Combine surface.
It was enough to solidify it, even if, for security, you can also use the "Repair Body" command. .
Thank you! It was necessary to repair the surfaces! Thank you!
