if I click on the switch nothing happens. I repeat, the acceleration is disabled otherwise I should check out all the various caselline to check related to graphic performance such as antialisiing, shadows etc. for a further proof that it is disabled you place this screen:It's a switch. . .currently set to on, if you want to turn it off you must move the control to off. your acceleration should be active and you also understand it from the phrase that says "disactivate only if there are problems of graphics.... "
but if you click on the switch what happens?
Can you see the hardware acceleration button? here's the one to be active should be blue, but it's grey because it's disabled.Yes. I put the last available from May 26th.You're right, my mistake. Have you tried to update the drivers of the card yet?
try to install the sp1Same problem, too. .
I came to the sp2 but nothing to do.. .
