command confirmation with double click
  • Thread starter Thread starter citri
citri
hello to all
from a few weeks I have installed the new version of mechanical 2015 but unfortunately I am finding a small problem that however gives me a lot of boredom. practically, when I use commands like size, extend, change properties, etc., I have every time to double-click on the object.
I saw that holding down the ctrl key, I can handle the problem with just one click but since I've been used to working with the single click for years, I almost always have to repeat the command.
is there a possibility to set mechanical for you to return to work as in the past? Thank you.
Excuse me, what do you need to double-click objects? to make every choice? for example with the command size: double click to select the cut line> double click to select the line to cut?
However try to control the action of the double click in which.
of the type that select the command cuts, then the cut line, I confirm and when I go to select the line to cut in the moment they place me above with the mouse makes me see a preview of the cut (that also this preview thing I never had and I'm hating it), I click once and practically nothing happens, I click the second and cut the line.
If instead I have more lines to cut and I want to select them all at once, I open the selection window, select them (and always shows me the preview), click but in the end I only cut one if instead I press ctrl me cut them all.
so it seems that it is some setting of 2015, that I do not have. try to look at allla tab options User preferences e selection If they are still called so; window selection method e preview selection that could hit something
I have installed autocad mechanical 2015 and this problem I have not...
The service pack 1 has just come out... try to install it and see if it solves the problem.. .
@massivonweizen I will try to do some tests as you say
@figor71 I already installed the sp1 but the problem persists.
now I will experience some in system options, thanks to the help
discovered (spero) the ark mystery... in options -> selection, I had to remove the check to "before the command", now seems to work as before :smile:
