problema con le viste
  • Thread starter Thread starter Gianfr
Gianfr
Hello! My question is:
can you rotate or move a view with the manipulator once this has already been defined? I have on the sheet a view that would be rotated 180 degrees, I tried everything but I can't. Thank you in advance.
If you go to the property of the view you should be able to re-emerge it by defining the orientation to aprtire from 3d
