pack and go su ug
  • Thread starter Thread starter spantik
spantik
hi to everyone: simple question (I don't think I found answers in the forum). Can someone tell me if on ug, from version nx5 up, there is the equivalent of the pack and go command of inventor? (except obviously do the classic zippone of everything)
Thank you very much
Thank you very much
create clone assembly. I don't know inventor, but it should press the same thing.
in nx9 the command is in assembly - cloning - created clone assembly.
so (if I understand the problem well) makes you a copy of everything, or part of your set.
otherwise, carry out in jt.
qui http://community.plm.automation.siemens.com/t5/nx-design-discussion-forum/bd-p/nxdesignforum trovi una customizzazione che, oltre ai vari template, ti consente di avere nel menu questo strumento: zip assembly.
p.s. note dell'autore:
about nx90custom last modified: 23feb2014
what's new:
the nxcustom ribbon
note: to customize the title in the upper left, edit the title line in the nx90custom\nx90library\menuscript\startup\edit_ug_main.men file.
the title line can be deleted to show the default title, which is the current nx version. the title command only works for the nx product.
revision history:
20oct2013 - nx90custom_reva released
1jan2014 - nx90custom_revb redirect help > training to learn@siemens website
17feb2014 - nx90custom_revc corrected materials library environment variable
added bundle command line to group1 batch file
18feb2014 - nx90custom_revd added nxcustom to ribbon
23feb2014 - nx90custom_reve added manufacturing bounding box to ribbon
replaced ugii_vendor_dir environment variable with nx_custom_menus in nx90env.dat file
Thanks to everyone, you were really helpful. Yes, the pack and go of inventor, practically unifies all the files that have been used, to develop a "x" project, allowing you to pass it to another designer, without omitting details or assemblies.
perfect.
Thanks again:4425: :36_1_11:
perfect.
but duplichi your project.
Are you sure this is the only way?
"The other designer" isn't on your network? Can't you share the job differently?
I find this pack&go or zip assembly or clone or any other data duplication, something wrong and potentially devastating.
Sometimes it's a necessary evil. the reliability and speed of the adsl networks are not enough yet to be able to work from remote locations on the corporate server, so it is necessary to send back and forth the project files with all the various related documents attached. On the other hand, the cost of distributed data duplication systems or file systems is not available to everyone.
with solid edge and solidworks you can make the shipment in packages preserving on arrival the same structure of the directories that was there at the start, thus preserving all the various interpart links. working with a certain attention of damages they do not.
Hello hunting.
for a certain period me and a colleague have experienced with discreet success the use of dropbox just to work in team on the same project .
Obviously upstream there must be some specifications to follow, but once defined "who does what" we did not have had hitch for a long time.
This system also allowed us to have a backup of the various saves over time so that we can also recover old versions after a rescue.
from that moment I also use it as my immediate bakup security, of course if the customer does not require an extreme privacy level
