problem with roof
  • Thread starter Thread starter jamba_ITA
jamba_ITA
Hello everyone,
I'm doing some evidence with revit and I have some difficulties with roofs.
I will attach you some examples screenshots. I have made the roof in more hawks because in the plant it does not have a regular shape and therefore I would not be iruscito to realize it by extrusion.
the various bonfires, however, as you see with them coincide. If I align the extremity to the indradox I have a difference in height and the same happens if I train the intradox.
I also have a problem with the pillar. I associated it with the ground, but as you see, the head is always horizontal. . .
Can you help me?
the pillar does not change the head only because you associate it to the roof. If you want me to do this, you have to parameterize it.
the cover problem is simple geometry. If you have constant thickness parallelepipeds by matching them to different slopes, they will not be able to match perfectly.
You're right, but it doesn't seem logical to have to "return" the thickness of a layer. would it iruscize to create a cover like that in the image with a single layer?
other question how can I ask not to see the lines of the horizontal division of the walls in the prospectus?
I don't think so.. .
join them
reading among the various forums I found a solution to build the roof with a single layer. I realize it with roof for extrusion then "elimin" the parts that I do not care with the vertical hole command. I think it's a good solution.
I try with the joint command.. .
