wheel- track coupling
  • Thread starter Thread starter onizuka
onizuka
Hello I have a set that represents a railway car and I would like to pair it with rails that correspond to the other together, provided that the wheels of the cart turn quietly on their axis, I can not find the right constraints.
thanks in advance
if you have the mechanism module I recommend a pin or general connection and then define a rack pinion gear. if well defined, you should have a very real movement.
Hello I was trying in the fracturing the ''camma' between wheel and binary surface but when they select the high part of the track tells me: ''the automatic selection fails to determine the direction of the cam for current selections. continue with the selection of surfaces. '
first by chance I don't know what I clicked with the mouse cursor and selected all the ''rotaia' part and it worked, I had to go back for a failed savour and now I don't re-echo
then: I managed to select the track by selecting all the surfaces, I inserted a servomotor in the wheel but at the time of making it work turns but ''stop the cart''' I tried to insert from check coeff. of return and friction but nothing, I'm doubted that something is not wrong in the coupling of the wheel with the track
You're unnecessarily complicating your life. Try to follow the advice I gave you!
I'm trying, but I have a problem, how do I define a motorcycle axis on the rail?
the wheel must not have any axis of motion, since it must definitely stand still. is the wheel that will have a pin or general connection.
when I create a connection gear rack, I give how to gear the wheel, and then as rack I try to select the rail but asks me a motorcycle axis
I saw I tried, but there's something in my set that doesn't come back to me, I try to allegarle the axieme to see if it succeeds, '' axis cart'' I would like to insert it into '''try rotation'''
I can't open it. in the test_rotation is recalled asm0007 that is not found.
Sorry I messed up in the folder I have other project components:
However I would like to create coupling between ''base_carrello'' and ''asm_o7'' which are the rails
Now I realized where I was wrong, for what the wheels didn't move, because the coupling with the tracks I did with those instead of with the plans, thank you very much without your example I would have lost days in a glass of water thanks! ;)
