Ste80vi
look, I can provide an indirect experience with regard to the drawings that come to me here in the company from customers I think have the flower of the three-dimensional since the sheet is their daily bread: flat view is provided by their own 3d but elegantly solve the problem with a nice squared citadel note: "indicative development". as you say correctly, a technical study must not go to the point of pointing out a profile that has the claim to provide to those who have to carry out the work materially the proper development of the artifact. In my opinion it is impossible! instead a technical study of a company should analyze a design and prepare the developments to be sent to cut, in that case it will no longer be a phase of design that will serve, but a phase of planning as it will go to analyze a series of factors, like precisely the type of bending tools, the real bending rays that follow it (going to compensate therefore those areas that must then be well coupled for the subsequent operations own welding,
In my opinion, to provide a development that presents the only theoretical internal surface with r0 rays, or that instead provides a surface relative to what would arise with a k equal to 0,5 (i.e., with neutra fiber in the center of the thickness) little changes : however, those who must realize the piece must be resumed in hand, shortening or elongating the zones in correspondence of the bendings. Then, I have seen of all colors: I have seen companies (in fact, aziendone) start with the cutting of a prototype adopting the development of the design of your client (to understand the one with the written "indicative development" to see where you go to parare! I have seen the delivery of pieces to be soldered in tig with thickness 1 for which even a coupling summary highlighted huge gaps. An example? the discharge in correspondence of the folds, that is the circumference that is used to make in the area of the edges to ensure that the compressed material of the bending does not go to "urtare" with the adjacent bending... if you consider the bending radius generated by the tools, that type of unloading is useless. complicates and extends only welding operations, aggravating unnecessary costs. Therefore, to say all about it, the drawing of a piece to start production from my point of view also means having to "review" a whole series of details to which - more than rightly - the designer does not think, but that a technical office that has the task of "to eat" laser and bending machines has the obligation to do to make quality pieces with more efficient times possible. and it is not at all discounted!
Back to your problem, if I have a little time I will try to make 4 accounts but I am very doubtful to be able to find a k that allows you to get to your result... you will get semmai (perhaps) one worth for each radius and thickness, but not for every bending angle......
a greeting and good work to all!
