missing tree after operation hide
  • Thread starter Thread starter otiea
otiea
Hello, everyone.
I'm working on a top down product and in particular, I was working on a rough shaft. After doing the two parts, to make the quarry in the tree and in the hub I hid the tree and now, once I made the tab, I can no longer see it.
when in the click tree on the view/hide part, it remains hidden.
I also tried to change visuals by clicking on the piece in "change visible space" , but it does not return.
possible that the problem is due to the tab that has not been properly dimensioned?
thanks in advance
But how did you hide the tree?
if you hid it by selecting the body in the casket specification tree, you see it shaded and you can view it again,
If you hid it by touching geometry in 3d, you hid a feature, then you have to open the body tree and then display it.
Remember, always hide from the specific tree
I honestly don't remember how I hid it but at this point I think I did it by clicking on 3d geometry?
I tried to click in the feature tree and there is a hidden icon that however I can't reappear by clicking view.
strange... let's go to the strongest methods:
select the body, then right click, at the bottom where there is xxyyzz object, in the under menu there is displaying components. . .
eye that displays everything, but just everything and then you will have to hide what you don't care.
ps be careful that if you have the active product or another active part, the hidden display is partial, so always activates the part on which you change the display.
I don't know what happened. I decided to remake the piece, so much is a tree. Is there a way to erase the whole body without having to delete every compost?
if it is the partbody (the main one), it doesn't make you do it, you must first create a new body, then replace the partbody
Thank you very much, in the end I solved with the tree opening it as part and not in product, saving and returning to the product. must have been a system bug
in fact in the first suggestion I told you to activate the part, since in the product the hiding/visualness is partial
I don't think it's a bug... the system, having to work with countless products and parts simultaneously, is forced to discipline changes through selections, hide or color a features in the product modifies the properties in the product and not in the part, just reload it and return as before.
