construction of a solid between two parallel polygonal faces
  • Thread starter Thread starter mauriziolrosa
mauriziolrosa
I can't build the solid between two identical parallel faces.
ps solid can also be used another technique such as e.g. rake etc..
here the link to dwg autocad file 2014.
- transforms the two 3dpoly into the region
- loft between the two regions
- scolpiscisuperf by selecting regions and loft surface
thanks your advice was very helpful and I solved the problem.
