colour difference
  • Thread starter Thread starter Zio Sam66
Zio Sam66
Hello, everyone.
After importing a rhino part without any error (at least visible to me), I added simple features but in one of these, a surface created by extrusion is of different color. Can anyone explain why?Capture.webp
the reason I can't explain it, but when it happened to me to solve it I had to do "delete all aspects" (the model turns white) and then reassign the color to the part
hi massimo78,
I had the same problem importing files from iges or step but failed to solve the problem by deleting all aspects.
It was a combination and some parts of it even if repeated several times I could not give a color.
Are there any other ways to solve the problem?
what does all this depend on?
a suggestion, hoping for functions...
using models in the import should correctly assign the default color.
you maxopus usually amount so and all the part or all the axieme takes the default color but when I go to color the surfaces. ..that "damaged", ...damaged were and damned remain
:rolleyes:
Perhaps the process is already known, but it is possible to color the surfaces in two ways:
first select the desired appearance and then the coloring surfaces
or
first select the coloring surfaces and then the desired appearance (the latter can also perform the selection of the surfaces with the starting and limit surface method).
hi massimo78,
I imagine you have already tried to open the single part and "delete all aspects" within it and not as a whole
Unfortunately I don't know what to say, because that way I always managed to solve
There should be tests on the parts that return this behaviour.
so on two feet it is difficult to identify the problem, at least for me.
