impossible to save in the style library
  • Thread starter Thread starter Tarkus
Tarkus
-modified a material and saved.
-close and reopen the file. verified that the changes were saved in the file
-management
-texts and rules
-Save styles in the style library
- "yes" in the style to be saved and do ok
- message quit that the style library will be overwritten-> ok
Here we are at the puzzle message you see in the image.
Does anyone have any ideas about it?
nothing to do with the old method of rebooting the pc.
I took a look around and it seems that you don't understand only with 2015 and not only with bookcases.
It happened with older versions and ipt or idw.
even in a classroom a teacher has installed 10 or 20 pcs all the same and only on two from the problem and you do not know why.
I would be in you, hoping that 2016 will self-adjust itself.
the only proof that I think of recommending you is to create a copy of your date design, make an update via "system library management" and create a new project that points in this new folder. then recreate styles and try to save them.
