nx 7.5 moldovawizard: can i create more than 2 branches?
  • Thread starter Thread starter betana
betana
hello to all, I wanted to ask you if with Moldovawizard using the standard part I can create all the branches I want to help the designer choose?
hi, I try to explain myself better; in the customer default to the Moldovawizard item I can create an order of the catalog of standards part but this order can also accommodate under menu ? know that in the xls or xs4 files I can create a submenu with inside the various members but if you want to create more complex submenu? for example now I have a menu consisting of 10 categories including accessories, fluid dynamics etc, and inside for example of accessories I have a menu "center rings" with inside 5 or 6 members; If I would like to make type accessories--> customer-->pincopallin--> injection-- > center rings would be possible? I don't care how but only if it's possible and in case I do a couple of days of advice. Thank you.
I don't remember what version of nx, but now you can organize the folders (if I understand what you want to do) using the reuse library.
