TECNOMODEL
I would need advice on the best method to operate:
I am beginning to create the library of i-features,works etc. that I will use frequently.
I would like to create the library for flange sae attacks and think about the best method to use.
I could make an i-feature of the profile and from time to time insert the size depending on the flange size to use.
then with another i-feature insert the 4 fixing holes and with a third the central hole.
In this way, however, I should have a table with the size each time that "pitch" one of these flanges.
or create as many i-features as the flanges and as many for the holes.
Finally I could create a part containing only the sketch of the profile and derive it, but in this case I should always have a ucs so that the origin of the sketch coincides with that of the ucs.
how do you settle in cases like this?
