resize objects
  • Thread starter Thread starter BeboCreo
BeboCreo
I have a problem with creo, a colleague of mine has spent a piece to place in an assembly, the problem is that it is much bigger than due, how do I resize it?
Good morning.
say a presentation is welcome in the appropriate area, as from regulation.
for your problem: I would correct the wrong model.
You can try to climb it, but personally I don't find it a valid solution.
edit: I correct myself, with I create climbing the model, I can keep the tree unchanged. In practice it is not a feature that you go to add to the model tree.
take a look at the units of measurement, because if the difference between the pieces is 25,4, someone worked in inches.
sisi the units of measurement was the first thing I checked, however I found on the internet that with the svergola command you can resize ( simply with the mouse dragging a corner) to pleasure the various objects, the problem is that I did not understand if I can put a factor of proportionality
If you are looking for the online guide, you will find the "scale model" command. I think it might be okay.
