automatic printing drw
  • Thread starter Thread starter lollone
lollone
sometimes they come back...it's been a while!! !
I find myself having to cuff on pro/e, indeed now on creo!
we often have to print pdf drawing lists (about 30 tables).
I wanted to understand if there is a way to facilitate the operation without having to open the drw and print them one by one.
There were already discussions in the past but I couldn't understand much. . .
I use wf4.
if you mean how to print many pdfs, I use foxit reader (it is a free program), I open all pdfs that interest me and I put them all in one shot.
While you mean how to open in a blow only 30 .drw, this I think there is no function of proe that does it (at least in the wf4)
Bye-bye
if to print you intend to export from drw to pdf you can do what you ask by setting creo distribuited batch.
Is that new name?
Okay, it's really simple to set it up, if you want, I can help you out.
Meanwhile you have to see if you have installed it:
Do you have a qs icon below on your desktop or in the boot menu?1623_14052015.webp
Yes, I think so, you simply will have a different name topo pro distributed batch
ok, click create new group of operations0943_15052015.webpI to do qs work use function pdf drw multi page export0954_15052015.webpclick on the folder to add your drw files to export to pdf block0958_15052015.webpthen add a configuration file for export (a config.pro is sufficient where for example the axes dots are switched off etc... otherwise you print them all)1004_15052015.webpin the outputs choose the position of the exported designs1009_15052015.webpwhen all this is completed exit from create parametric (qs program requires a free license to work), click dx on the new group of operations, then start1012_15052015.webpNow go drink coffee, come back and then let me know what happens:
My softerist tells me to have it installed in his time. If it were true where the icon should be? in wf5 of course.
