change of parameters in axioms
evaclo
I am now approaching user parameters settings, and I am not yet clear about some functions.
especially I would need to be able to change the parameters of the individual parts directly in a set (maybe through ilogic module), but I can't understand if it is possible to do so and possibly how.
I explain to you in detail through a simple example that I am creating:
a) I designed a set (panca), composed of 3 parts (base, back and feet)
b) in each part I have defined a key user parameter that interests me to control, also defining a multi-value list
c) in the axieme I connected the 3 parameters of the 3 parts
at this point I would like to be able to change the individual values (selecting them from the list created earlier), but the values are not editable... :frown:
I also tried to create an ilogic module, but also in this case I set the value as "read only" and can't vary it
Can someone help me solve the problem?
in the set you need to create 3 parameters and in an ilogic rule you must assign to the parameter together the parameter value part.
This way when you change the parameter together automatically you will vary the parameter part.
Thank you very much!!
I ask you too much if you could tell me the generic syntax of the rule?
could you also control the material and color through ilogic?
Look at me as soon as I'm in front of the pc, I'll put the rule on you.
certain you can change material color etc
perfect, tried and everything works!!! :finger:
thanks 1000 heart
ps: but if you want to be able to choose between 2 0 3 materials/colors? with the size is quite easy, I create a multi-value list in the parameters and connect it to the ilogic mask, but with the materials/colors where I go to set them?
Similarly create a multi-value text parameter with within strings contained in the list of colors and materials respectively.
Cattura.webpattention that the program and case sensitive then respects uppercase and lowercase.
All right, all right.
I created the text parameter with multiple values list, associated with the text to the color field, created the rule to associate the text parameters of the parts to that of the axieme.
Everything works very great! !
Now I have to understand the difference between materials and colors and then I'm fine.
I don't know how to thank you, you were really kind, good to make:finger:
the difference is like in heralth .. e.g. you produce something in steel (which has its associated color. . )
but this if you leave it to the weather rusts; then give it a nice paint ..
paints exist to this world!!
Here, the material has physical properties and its appearance,
then look you can change it at the end with something else
I fully share eugenesis post
the material contains information in more than color (mass, mechanical resistance, etc.)
I'm going back to this post. I need to change a part by commanding it from the assist.
but if I then replace the part or anyway the part changes name? are there solutions?
change links manually :d
However if you want to do it automatically we could be an option explained in This post, but everything depends on your case/workflow.
