deduction and filling models
  • Thread starter Thread starter sandrix
I ask how to use restraints and fillings
do you intend to use them correctly according to iso regulations?
there are working methods for fast working with fillings/tracing
in particular I refer to the contours that often have problems with unclosed vertices etc.
the fastest method is to display only the contours that interest you, or turn off all unnecessary layers, and verify that they are closed
Thank you for responding to the post!
I don't care about the law
I care about a method you work to quickly get fill
avoiding the problem of closed contours....
and how does autocad create a closed contourless restraint? Do you make up?
you can use the gap tolerance but I don't know if it can go well as workaround
I imagine using a command as a covering entity that generates a contour and then fill it with restraint...?? I recalculate them....
then use a polylinea to get a closed contour and put it on a layer non stampabile
with autocad you can play with the commando boundary............instead with artcam or aspire is better and faster.......... and you can also the geometri that will close the stretch (right line or arc) according to the needs
