Hawks-IT
Good morning, everyone!
I am new on this forum and for work needs I wanted to ask you help for a problem I have encountered.
I currently use inventor 2015 pro, when I carry out any study of a machine and then I extract the distinct components to order them, I realized that the count of the bolt and also composed of the screws or dice contained inside the welded with inseparable structure. any assembly containing sub-axis of assembly with "normal" structure; welded with "inseparable" structure; single details with "normal" structure and finally commercial and bolting with "acquired" structure. the welded ones contain sometimes of the bolt, being inseparable structure do not rightly count the details that compose them instead the bolts bypass the inseparable structure of the welded and are counted together with the rest of the unwelded bolt.
in this situation every time I have to manually remove the bolt welded by the total because
