version 2014 inventor
  • Thread starter Thread starter Chiaretta
Chiaretta
Good evening,
I would like to ask you a question: for work I will find myself having to work with inventor (until now I only used solidworks for 3d modeling) as I will have to interface with a company that uses this software.
to take our hand I intended to use the trial version made available by autodesk but this version is the latest release, i.e. 2016, while I would need 2014.
Can someone tell me if you can find the free trial of 2014 somewhere on the webspace?
Thank you in advance;)
good day and good work :smile:
if you try 2016 and then go to 2014 you don't notice.
do not dream of doing something to use on 2014, versions, as you know, are not retrocompatible.
Besides, making use of a trial copy to produce non-personal files, is an incorrect procedure.
autodesk is proposing the monthly rent of licenses, it could be a solution.
Yes yes, in the studio we will take an autodesk license but a new year. the interest towards the 2014 version is simply related to the fact that the files I have are 2014 and knowing that the opening with 2016 compromises then the opening with the r2014, I was wondering if the trial version could be found also of inventor 2014.
My intention is to know the program, no more:)
if your customer uses 2014, you will also have to use that version. said this, before renting the license check well that it is possible to have the release 2014: often happens that soft rentals are only available to the latest version.
inventor for rent you only have it in version 2016.
If you buy the subscription together, they give you the opportunity to have the two rel. prior to the current.
If the problem is in the terms you described, ask your customer the dvd or the usb key of the 2014 rel and the mountains as trial.
this is the solution, remembering that the trial lasts 30 days.
Sorry, but now there is 2016 and I can use 2015 ( never mounted) and 2014.
in April / May 2017 will come out and, at that point, I would be out of maintenance with 2014, wrong?
from the subscription site, I can only see the licenses until rel. 2014.
