yuri55
I used cad as creo2 and catia v5 where the solid modeling is carried out mainly through sketch, regarding nx has a slightly different way of reasoning than the 2 previous cads I tendentially use here sketches but to what some carmaker told me to model in nx with the chunky model without the use of the sketch, do you understand?
I bring you a simple example, if at a cube I have to subtract another cube on nx I can also not do the sketch but the curves not drawn on the sketch are not parametric or better I can change the length of them but if I have to change for example the distance from a edge of the first cube how should I do? Are you using offsets?
if I have not been clear I remain in disposition for clarifications
thanks for the info...
yuri
yuri
