salsero
Good morning, everyone.
I write to you because I am encountering not a few difficulties in the parallel use of inventor and autocad.
I understand better... for my projects I need to make a virtual assembly and give mechanical constraints, so as to verify the a priori operation of true assembly.
In my case I have to bind trees with relative plates to the ends that through holes that transmit motion through rods to an identical mechanism on the other side of the assembly.
I have drawn all the details both as plant 2d quoted etc and as extruded 3d.
I would now like to import the extruded object or at least design 2d within inventor to realize the aforementioned assembly and then give mechanical constraints but I can't do anything. ..can you please indicate a procedure to import autocad designs to inventor and then work on it?
