divide mass
duedan
Hello everyone,
I am "impratichendo" with the masses and modeling with revit.
coming from other modeling software, I'm trying to figure out if there are ways to do certain revit operations.
I would like to know if you can divide (or cut) a surface of a mass with reference lines drawn separately and "projected" on the curved surface.
I understand I'm not very clear with the request and so I try to explain myself by posting some pictures. from image 1: of the blue surface, I would like to separate the "pinna" by cutting the surface with the semi-ellips designed as a reference (picture 2) and then subdivide the latter with the instrument "divid surface" and then apply a family of panels. with the same procedure, I think, I would like to get the arches drawn in image 3 on the surface highlighted in blue in image 4. It comes to me only in mind, as in rhino, "curve project" or to make boolean subtractions...but it seems that you can't do it.
Thank you.View attachment 42887View attachment 428861.webpView attachment 42888
in fact (unless you use dynamo), but no one forbids you to do so in rhino and import the surface into the editor masses of revit
I thought that the masses, since they are conceptual, had more freedom of modeling and so they could unleash me from other sw.
Boolean subtractions. use the reference lines to make the blanks, and then, do the subtraction.
