advice on buying video card
MatteoDD
Good morning, I would like to have your opinion on which video card to buy. my pc mounts: an intel core i3 3.30 ghz, 8 gb ram and for now it still has the built-in graphics card.
with the built-in video card it became impossible to work on it as when I go to create assemblies a little more complex it starts to hang.
My choice fell on the asus gt610 2gb ddr3, do you think it's okay? Do you have any advice? my budget is 50/70 euros.
thanks to those who will answer:cool::smile:
the nvidia gt are safer than the integrated. 2gb ram video dedicated safe that is different than the integral
Thanks for the answer, it counts that I am a student and do not do very big jobs, so it should be fine. Can it be okay with autocad 2014? ?
with autocad is all right if you don't make shed layouts with inside 5 100 meters plants each
I strongly advise you not to use professional tabs like painting. is not a problem of performance itself, but of stability. If opengl drivers are not well done, you may have, as well as instability, odds that disappear, seen without some rows and odds in general.
if your budget is so limited, go to the used with a card like the picture k600.
I don't want to give judgments. ...as has already written mechanicng the gt 620 definitely goes more than integrated but do not expect great performance...if you want a bit more brio you have to raise your budget to about 70-100€ with some more performing vga type gt 640...740.. .
evaluates well because you would risk finding yourself with a vga that may not fulfill your expectations.
Bye!
If you have to make rendering, unfortunately I do not believe that a 60 euro card can provide you with the necessary performance, so even if you have to animate something.
If you don't get at least 160 euros you won't have much difference from what you already have, as mentioned above you can throw yourself on the second hand.
sincerely second purchase, from private I would disagree, many are players are exploiting the cards "to blood". many of these can give you problems even with the simple break of fans, finding the component to be repaired is a bit of a bitch.
Maybe from some certified store that can give you something regenerated.
However for the compatibility issue https://www.solidworks.com/sw/support/videocardtesting.html here you have a table that allows you to check the model before buying, so you should not have surprises.
