3d orbit of raster images of a dwg from pc to tablet
  • Thread starter Thread starter Drawne
Drawne
Good evening, everyone. as from title I need to display on tablet the created dwg with autocad of a 3d design containing external references (Raster images) .
the problems are three: to transport external references, to be able to orbit in 3d and to find a suitable app.
How can I do that? I have to make an urgent presentation. I hope someone can help me. . .
a360 I fear you don't take the xref rasters, but here I say it and here I deny it...
I tried to make an e-transmit of the file but once opened with a360 I still can't view the raster image. the problem is that in the app you can't put your hands on xrif paths. Also you can't incorporate xrifs to the host dwg when it comes to raster images, justified by the huge size that could take the file.
I would like to try to play with the folders and the type of complete-relative-nothing path even if I do not clearly what I should do; the thought is that perhaps by directing unique paths already from the starting dwg they can be maintained, easier to say than to do.
for now I don't even try with pro
any ideas?
I tried to insert the raster image with "no" path but nothing. I think it's a big limit.qui the support page though says you can do it, but it's in fact that I can't
there are developments: I logged in my autodesk account on the site https://www.autocad360.com and then uploaded the image file from there. Once the dwg opens I can see the raster image inside it, but the cutout I had made in the original file is not maintained. This happens to me also with autocad when I transfer a dwg with raster images cut out in another pc. what is the error?
My fault: login in a360 I took it for granted, regarding the crop I don't know, I have to make some proof myself. can you upload the dwg file?
I attach both the dwg and the image, of course it is a proof. the image comes out from the rectangle that should instead refer to for the crop, or at least so you see if I open the file from autocad360
  • Disegno1.dwg
    Disegno1.dwg
after several tests I renounce.
the app recognizes the missing connection even if the images are uploaded correctly to the cloud.
bug to report
I don't think it's a autocad bug, but the app a360 that doesn't properly handle references (or handles them but you don't understand how)
