a distance during a movement
  • Thread starter Thread starter MBT
MBT
Excuse me if I write in an area that is not typically mine
Suppose we have a set, with some moving parts
the share that governs the reciprocal position of the parties is driven by a relationship linked to a parameter (in simple words: change the parameter, the relationship updates the quota)
We also suppose that I took a distance between two parts and saved as a feature
I would like to see how this distance changes to the variation of the reciprocal position parameter, giving it steps (e.g. from 0 to 10 degrees with 0.5 degrees steps)
what I would like to have, at the end of the nottata of calculations, would be a xl sheet or a chart that tells me for every step what was the distance
What do you think? How?
thanks to all
Sob. Sob...
40 visits and not even a word of comfort. . .
Sob... They put me, me tapino, me derelitto. . .
What you ask is not a simple thing. the most I managed to do is what you can see in the short video that I have attached. if you can be enough, you get very simple, just put some odds in the right place and the game is done.
Thank you for having responded.
Unfortunately in my case the situation is not so simple.
the axieme is much more complex and "drag it" is practically impossible
not only, the movement of one piece compared to the other is linked to a relationship (in practice the axieme a roto-transla while the axieme b remains firm)
There is therefore no direct relationship between the command share and the distance I would like to monitor.
I use the remote control between two parts in my real estate.
and... with snapshots. Have you tried to use them?
Ah, yes.
But I hoped I could do something "automatic" that changed the parameter that governs the quota, verify the distance, writes it somewhere (xl???????) and repeats the calculation with a slightly different parameter
... something "automatic" that changed the parameter that governs the quota ...
I throw it there, and an instruction of the type x = x + 1 in the relationships, to each regen the parameter increases and consequently the quota.
Is it a slow and sluggish method?
I had a similar case and solved it, with nx, but I think that any other cad does the same, making nx arrangements loaded on a single set. the procedure is a bit heavy but appropriation.
I hope I helped you.
This can be a solution.
is there an automatic method to recover the distance and maybe "save" it in sequence in some files?
- - - updated - - - -
Yeah, I get it. a kind of "pattern"
could be a solution
to get the distance just save it in a feature, but write it in a file I see it hard.
Sorry to allow me to give you advice. In some cases I follow this method:
with pro-and I make all the calculations that I need, then the same type of calculation I impose it with excel or other similar programs keeping them separated deliberately, also because so doing I keep under control any errors, if not return the same results I put in alarm.
When I need to woven the data I prefer to import the results obtained with excel in the project, which is simpler, I can build a curve with the data imported from spreadsheet without many complications.
Hi, dani! I'll answer you better tomorrow I have more time.. .
Maybe in the meantime try reading the guide by typing "excel analysis" is explained well.
Okay, all right. Who knows can't serve me in a future.
Here I am, I try to explain briefly how I worked:
premessa: for simplicity I collect in a group all the features of analysis at the bottom of the tree of the model of my set1300_15032016.webpstep 1: after doing all the distance analysis features, last I do an analysis features (generic)1301_15032016.webpstep 2: I define step by step the feature as required by the program1303_15032016 (2).webpstep 3: nel tab definition I go to take the results of the parameters that interest me and the measurements away by associating them with a precise row and column of sheet 1 of the excel file. excel sheet can already be existing (as it was in my case) or can be defined at the moment by new1303_15032016.webpstep 4: eventually save the excel sheet:redface: (I tell you why when you finish the analysis feature, the excel file you were working on closes you directly and you have to start over :wink:)advice: nel tab richer non put on always otherwise at every change of the axieme is very slow and becomes annoying to work. I put it on solo studio prog and at the end of my changes to the project when it is time to update the excel sheet I just need to make a change final to the feature; click on succ and finally raise the updated excel sheet.important! ! ! once set the feature, on the excel file non do operations type add line-column; move cells etc... This is because the creo cannot take into account and the subsequent modification always inserts the values into the cells you told him at the beginning. It's a bit of a mess.
to solve the problem of mbt you see a little if putting together the suggestion of baskets and mine you can make some progress and maybe keep us updated all. Who knows that there is no interesting point in our work.
a good day to all
excellent explanation, very precise and detailed. the only thing I can add is that the system also works with the guided quotas, which I prefer to the analysis features, because they are more obvious in the project.
