export/save dwg with parts like blocks or different levels?
the odds are not halved, it is the particular that it is; this because you modified the scale of the viistes from the featur manager instead than from the property of the sheet then the program exports the views keeping valid the scale of the sheet and adapting the views.
if for example do a particular 1:2 of an object 1:10 when you expose the particular will not be like the original but larger than 5 times (it is not autocad where you use the windows in the layout to scale the views)
hello to all, I give up this interesting discussion... Has anyone updated this macro for the 2016 version or has an equivalent to indicate to me?
