Matricola_Gigi
Excuse me, will you give me some insight into the construction of the punches?
Hi, gigi. Your question is a little generic.Excuse me, will you give me some insight into the construction of the punches?
true eh:wink:ps: I realize only now that this debate has been protracted for an exact year: are you sure you'll get a spider out of the hole?
you are not well put....but have you produced and designed something or make you fold the printed sheets?true eh:wink:
in a year I entered the workshop once... you are
and mind that there is a norm also for how to fold the sheets.. .you are not well put....but have you produced and designed something or make you fold the printed sheets?
Right?the formula that is used as first sizing for the punch plate is defined by the following formula:![]()
Yes, indeed.sure that it is not the thickness of the matrix and the punch but of the plate that welcomes and guides the head of the punch.
keep in mind that if you make 10 holes diameter 10mm on a s275jr plate thickness 5 mm and a lot of 35% primer force we reach 80ton of press. do not want to drive 43 mm of cylindrical underhead of a 10mm diameter punch? the punch will have an increase of about 16mm...16 x 2 = 32....poco far from 43mm.
What do you see strange?
Hi, I'm going to "restore a little power": you have got chosen to make this 3mm thick brackets? Did you synthesize or did you just "eye"? because it sounds bad to me, much more than aluminum. what is al99.9% or avional?Yes, indeed.
I am trying to make a step mold for support brackets (n° steps 2), in a first phase the punch will remove the friction of the hole and the exhaust throat of the bracket, in the second step will draw the profile of the bracket.
we chose a thickness of 3 mm for aluminum, and the offset of 7%.
Hello againHi, I'm going to "restore a little power":
then, for charity, do as usual site, far from me give lessons.
