dimasa
Hello everyone,
I saw the tread at the link http://www.cad3d.it/forum1/threads/42502-creazione-di-un-blocco-su-coordinate-impostate-in-excelI have seen both the excel file, with reference to the page http://www.myengineeringworld.net/ both the other proposal with the excel file "creating blocks from excel.zip"
I don't understand aerophotogrammetry and coordinates, but I need to insert blocks into an aerophotogrammetry by taking this from the site of the geometries college.
I have coordinates provided to me on excel that refer to a particular point of the municipality, of the type "37.32825547985700 14.74298718055500" and at that point I should insert a block,
if I insert these coordinates in both files, they end up from anywhere other than the aerophotogrammetry plant.
Actually the point where I should place the block is located at the autocad coordinates "18790,2153 162658,3043" there is a formula to make them match?
or should I transfer the blocks, fix two certain points and then with a "alline" command align the blocks to the aerophotogrammetry?
Am I wrong with importing aerophotogrammetrics?
for the file "creating blocks from excel.zip" as well as the same problem of the coordinates, I would like to know if there is the possibility to use dynamic blocks allowing you to use the different display states, as well as give the necessary info to the attributes. .
I hope I've been clear, and that someone can help me, say hello
