creo 3.0 configuration help + table setting
  • Thread starter Thread starter Cla
Cla
hello to all, I'm a little rusty and it's been a while since I put my hand at the terrible config.pro.
I would like to set up some things (I'm reading the guides and what I can do from me), but I would have biosign advice for the following points:
1 - when I start I create I have a mistake like this: line 4: unknown keyword auto_round_member -> what is it? I want to avoid it.
2 - I would like to avoid opening the initial windows with tutorial guide, etc... -> what is the setting that disables these windows?
3 - I would like to be able to set up the table once and for all, I try to give the correct impressions but when I start a new design I am point-to-head - > what is wrong with me?
4 - there would be so many other things but for the moment I would say that it is enough:wink:
Thank you!
As for the first two points, I think the best solution is to consult assistance.
as to the third point, you probably did not configure the *.dtl file that manages the table. in the guide you should find instructions about it.
auto_round_member:
look if you have an option called "mdl_tree_cfg_file" and which file points.
you probably have a tree.cfg made with an old version of proes, I suggest you do it again for creo3.
for windows when booting loaded in the browser test these config values:
enable_learning_connector no
for the window that opens you beyond the browser reply not to show it again and save the window settings (file-options-sets window)
auto_round_member does it to me too, using a start part created by me. .
and yes, I have a "tree.cfg" pointed by config.pro, but created and used with the same version of creo 3.0
so it is not a question of retrocompatibility as of conflict between the settings from config and start-part settings (I believe...... in depth, and if I can, I will post the resolution of the ark... )
Anyway, you don't want me to. . .
but in the first 3 days of experience with I create, I made the idea that you deserve double salary who knows how to configure it, rather than who then draws us.. .
marries the philosophy "linux" or "fai-da-te" after having "bed-il-fott....o-manual"
that can also be good! (I like it..) but it really wastes so much time.. .
you have to set the path pointing to sected settings with pathways, recurring nightmares in matrioska.
but no, from the potential of the program is also this ... cmq to me despite having configured the tree.cfg every time I open a session the model tree is not like I set it ... mha ....
eh... because then from config.pro you have to add the right line
in my case:
mdl_tree_cfg_file c:\users\public\documents\creo\tree.cfg
Does it seem possible that a user is forced to do all these steps?
I ask you: if I carry out configuration files. ..... why should you never give me a simple way, within the graphical interface, to make these files the default active?
just a check box or something.. a messagebox with "si/no"
today more than ever the work is "categorized". who draws, may, should, but should not be a power user of computer systems.
and I add and then finish: Are you looking so much for the optimization of the workflow, with continuous technical updates, and then miss these things?? A nice "baaah" doesn't get it. I'm sorry.
provided that I have not yet managed to solve the initial error (autoround etc,,,) and the tree configuration file (it is as if I did not read it) I also have another problem ... if in the 2d I have to quote the distance between 2 entities (for example) I can not, I can only quote a length (I hope it is significant to make me understand this example) ... you know why??? in practice once selecting an entity I can't select a second one...
you must hold ctrl key to select additional entities
...which is absurd because it forces the user to press a hotkey for a multi-selection on a command that provides at least 50% of the uses. but vabe.. We can justify it with "you know what you do" but this "philosophy" has its limit. .
back ot, I have the same problem when in sheetmetal I go to add flanges on the edges. .
with ctrl I have multiselection, but then actually propagates the function and folds on the edges that it seems to him! aaarghhhh nervous
