worsenings of the 2016 version
  • Thread starter Thread starter Fabrythrash
Fabrythrash
Every now and then I wonder if there's someone who uses it inventor...
presentation/exploitation environment
the selection and displacement of the components has been modified, with the bad result that you can no longer select and move the component immediately:
- it is no longer possible to select the component from the browser and right click moves ...
- you must select it and if it is a part change the selection in the context menu
- use the upper control bar to tell him to move it, in the classic context menu the voice has been removed, I wonder then why, in this environment you do practically only this operation !!!
- select the center (triad) of movement
- uncheck the component automatically added to the selection if the triad is outside the selection group (this is then the maximum of the unbeatableness ...)
- move the component
- close the command
total of 6 clicks + mouse shifts against the previous 2 / x each move
on average I have to make 10/15 with a result of more than 40/60 clicks useless for each explosion... .
hallucinating is to say little for one who constantly makes it to make assembly tables
remaining on the subject, with the explosions, in the setting of the table in addition to ever modified the method of insertion of the views, that all in all "sembra" good, I do not understand why they removed the "snap" to the ball... there is no more to have the vertical/horizontal/radial alignment of the balls with bad final visual result and completely unlined pallination.
and I just started with 2016 ..... They...
I don't have the 2016 version but I'm also one of those who use the presentation environment a lot and already in previous versions the commands are questionable. It's a very hostical environment and you have to resort to many subterfuges and devote a lot of patience to make explosives as you must. I spoke a long time ago with an autodesk technician/reseller about the presentation environment if there were developments in the next versions of inventor, to what had been anticipated was not in the autodesk objectives the improvement of the Pinand that everything remained "frozen". Apparently it was even worse. ...
I don't understand why they took off the "snap" to the ball... there is no more towards having the vertical/horizontal/radial alignment of the balls with bad final visual result and completely disallined ball.
I'll bite them. They...
Did anyone find a solution?
I'm breaking my balls.
