explode a block contained in another block
  • Thread starter Thread starter rdilecce80
confutatis, I'm sorry if I'm back here to write you but I'd need another little help if possible.
attached, I send you a dime on which I have already used esptac.lsp
I have unfortunately found that the "notchs2" heels are stacked on the other and, according to the way, I should open the block and cancel the lines in submerged.
Is it possible to use, like, an overkill to eliminate overlapping lines directly from esptac.lsp or explode even these last ones by creating only lines on layer 4, in poor words, permanently delete notchs2?
Thank you for your patience
a
quando uso esptac, si crea la copia del blocco e me esplode
You're right, I just missed the fact that when I use vla-explode, the program makes me a copy of the entities that make up the block, keeping the original, unlike the explode command, which instead eliminates the block. Therefore the counter also went for his. Now it should be fine.
If you can filter them up, it's better, otherwise I'll have to run a control system for the block coordinates and clear the blocks too. However you do not do in 5 minutes...:smile:
the double notches created me after using esptac.lsp
I'm sorry, I don't want to be a pain in the ass, but the code looks exactly like the previous one:
(defun c:esptac (/ blocks gru dima index listadima count)
(vl-load-com)
(setq blocks(vla-get-blocks (vla-get-activedocument(vlax-get-acad-object))))
gru(ssget '((0 . "insert")))
(repeat (setq index(sslength gru))
(setq dima(ssname gru (setq index(1- index))))
listadima(vla-item blocks (cdr(assoc 2))))
count 0
(vlax-for elem listadima
(if (and (equal (vla-get-objectname (vla-item listadima count)) "acdbblockreference")
(equal (vla-get-name (vla-item listadima count)) "notchs2")
(progn)
(setq listaent(car) (safearray-value(variant-value)Vla-explode (vla-item listadima count))))
(vla-put-layer listaent "4")
(setq count(1+ count))
(vla-get-activedocument(vlax-get-acad-object) acactiveviewport)
Bah, I felt like I uploaded the new file, even because the old one no longer exists since I overwrite it. However a nice copy-paste finally solves the question:
Code:
(defun c:esptac (/ blocks gru index dima listadima)
(vl-load-com)
(if (and (equal (vla-get-objectname elem) "acdbblockreference")
(equal (vla-get-name elem) "notchs2")
(progn)
(vla-put-layer (car (safearray-value(variant-value(vla-explode elem))))))) "4")
(vla-delete elem)
(alert "tacche esplose!")
ps: tested on all file dima received
Hello confutatis, come back here. the other day you told me that you could delete through lsp the copy of the notchs2 blocks.
now the problem is more than ever annoying since the import program recognizes the "double line" on layer 4 and invents the heels.
wanting, if I make the concept simpler, the "double line" may also not be erased but stand on another layer other than 4.
If possible and if I don't bother you, could you give me another last hand?
thank you in advance whatever the answer is.
