note with director on piece .iam
Feg
Hello...
I use inventor 2014; I have a problem ... when at the table I put a note with director this last tip to the piece contained in the axieme of which obviously it is part instead I would like the arrow to give me the options of the axieme where the piece is included. If I wasn't clear... I'm available!
thanks in advance.
the note with director you can insert it where you prefer and you can move the tip. I have not understood your problem well, try explaining yourself better or make screenshots.
Hello and thank you for the answer!
example: I have a group having number part and description now if this together I put it on the table and I point the arrow "note with director" will give me (after choosing the parameters e.g. number part or description) the number part but not the axieme that I have on the table but of the component on which the arrow points
As I put together in the table and not the single piece I would like to have as note the properties chosen by me of the assieme and I repeat not of the part.
Now I can't post photos I hope I've been clear enough
customise the separate ball so that it does not give you the ethem but the description and/or number part
I know what you mean. Unfortunately, there is no way I know. with the director the command understands that you have to select a part and automatically gives you its number part. If you only used the text, it would give you the number of the aid, but then you wouldn't have a director. the only one is to create a sketch, insert a text with "number part" and create a hand-director with lines. I'm sorry, I can only recommend this.
Thank you... we wait for someone who knows some "escamotage"
