good evening to all, I can't get into the attached piece, a 16r8 spherical braking on the ramp but instead, it goes straight into the piece. I set any parameter but nothing.
Can someone tell me where I'm wrong?
Thank you in advance.
Hi.hi shiren and thank you for having responded.
I tried as from your attached image and finally the attack is ramping. the only thing I had to add unlike you to be able to attack on the ramp is the entry point of the cutter.
I would like to ask you the differences between the spiral grinding and the spiral grinding selected from the window by traditional procedures. You know, I'm working with toptron12 and I'm still at the top of my arms.
Thank you again.
you have to see if the 10 minutes on the camI saved almost 10 minutes.
sisi in fact with this procedure I saved almost 10
hello if you want to save time I would try with a parallel 3d roughing
fast there are very few, the cut is 95% in contact with the piece, so I think the time machine that gives me the program is real.you have to see if the 10 minutes on the cam
are real or you have to take into account the rapids
Yes, indeed, a few minutes less than the spiral 3d.sisi in fact with this procedure I saved almost 10
Thanks to you too!
I see that at last someone uses toptron, until now I have "known" (on the forum) very few.
and already we are very few... .Yes, indeed, a few minutes less than the spiral 3d.
Thanks to you too!
As for out-of-peer you can explain better. . .
I attached you an image.and already we are very few... .
practically allows me to check an option (minimum calculator length out of pliers) which, when the program has finished calculating the procedure, automatically gives me the minimum size of the braking that has to leave the clamp to not go to heel on the piece with the latter.
see you have set on advanced test to put automaticI attached you an image.
then you can easily set the length in the parameters of the cutter so doing when you make an advanced simulation if the heel cutter marks the gecko in red.....I hope you have been helpednoto the screen you see works, and in the initial roughing that did not allow me to enter the ramp.
the problem that this screen does not turn out in 3d roughing.
