Bonfi
good evening to all, as already indicated by the title, I would have the need to parameterize a sheet component, increasing its size of 0.5 mm per side rails, only that with the "direct" command I do not get the desired effect, but I get only an increase in thickness, so, I would like to know if there is a command that allows me to parameterize the piece while keeping the thickness unchanged.
below I leave a ".rar" file containing the above component.
Thank you so much in advance to all, good evening.
