generate parallel lines between two lines
leggera
Hello.
exists in autocad a function to generate parallel lines between two lines?
in tell there is a function that by setting an initial line you can tell the program you want for example 15 up to a point or line you select at a later time.
I need to have regular object distributions in certain areas.
I don't get this option. instead it is possible to obtain a subdivision of the space with the command divides.
then drawing a line between the space of the two lines with the split command and inserting the number of divisions are drawn n points from which then you can start the parallel lines
Okay with the divide, but you don't recognize the points you created.
I don't feel them as characteristic points.
What do I miss?
