mgdi
a greeting to the whole forum, all moderators and frequenters!
can you write renco....nito in the forum? because I've got it....nito and I can't get rid of the matassa below (just don't use more creo 3.0 m10 too often). .
I'm going to explain. .I would need everything to check with eye interference in different positions of a set
referring to the image:
- 1,2,3,5 are parts of the same group "a" (subassieme of the general axieme)
- 1,2 are rigid.
- 3 is a course that goes from zero (position in the image) to 40 simulating the stroke of the cylinder (and if I drag it with the handle it works)
- 5 are two pins that rotate without limits on the axes 4 (and if I drag them with the handle they work)
- place "a" fixed in the larger axieme using only constraints on its fixed components
- I should bind the axes 6 so that by changing the angle of 7 the two brackets 5 and the block 3 positions accordingly ....but nothing (even if necessary removing the constraint 40 max.).
I don't know if I explained... But if I had explained where the cabbage is?? ? ? ? ?
- 1,2,3,5 are parts of the same group "a" (subassieme of the general axieme)- 1,2 are rigid.
