320i S
"to separate bodies" or "play it as a set", is conceptually the sameBut no idea! a multibody modeler allows you to have inside a separate body part file. who can be separated and with father-son relationships (and will be partly related to modeling history) or separated without any relation father-son (and have no relationship with each other in the tree of history).
It is clear that if they relatize body or feature between them, I cannot reorder them, but while in the body that I then intersect, I can decide which of the two models first (always within the limits of the geometric relationships between them); in a feature based this is extremely difficult to happen, because it requires an ad hoc reasoned approach, which in simple cases can be done, in more complex ones, does not make sense.
in a feature based, if you have the possibility to have body, at the first level of logical tree, the body are like features for the system, and I don't feel there are very particular functions, such as fixing a specific material for a specific body and not to the whole part.in this context, of the multibody, I have to repeat a "but not even by idea!" feature based means that it is based on features and those reorders according to the parent relationships. If you work on two, three or n. disjoined bodies within the same part the various bodies can reorder them as you like in the tree of history. in swx you can, within a part, import a part from a file that can be neutral or native to swx. the imported part is placed on the existing geometry using the constraints that there is also in the axioms
In the example that you make solidworks with external mathematics, you do as well with creo through the advanced assembly, with part or all the math copied and imported through surfaces (command: copy_geometry), it is always a feature, but in the end instead of creating a body, you perform the solidification of the surfaces (by volume or by cutting).
my intent was to be as simple as possible to answer the phrase "solidworks is a multibody".I think you mess with the terminology. on hybrid modelers as if or nx I do not express myself having never tried them but there is a part of chce modeling is multibody and feature based and you can have a part of modeling that they call "sincrona" that if I remember well is histoy free, analogously to what happens with a contextual cad.
- - - updated - - - -
OK, or you're siamo....the net detachment with the caty past has done it passing from v4 to v5, is that to which I refer. They don't even look like each other.
the passage to v5-v6 instead is not of substance, is a little like the passage from pro-e to creo.
