cutting one part with another part together
volaff
Good evening,
I would have a curiosity.
is it possible in assembly environment to go to cut one part with another part (or better, for example, with a plane of a surface that belongs to another part? ? )
good evening to all and thanks as always.
with planes or surfaces does not seem to me, with the bodies there is the cavity control
We give the information a little at a time.. .
cavity removes a reference part from a contextual change.
If you need to do an offset by changing part of what you need to cut selections of the surface that interests you on the other side and do the offset
Thank you very much.
