reggio
hi, buying a conveyor belt with a special accessory, we realize that the supplier redirects the Declaration of incorporation instead of the declaration of conformity , having to resell it as we have received it We would like to know if it is right to receive and then to provide the declaration of incorporation or instead the declaration of conformity.recovering what is reported in the legislation
"The car is a
— together equipped or intended to be equipped with a system of drive other than human or direct animal force, consisting of parts or components, of which at least one mobile, connected solidly for a well determined application,
— together with the first indent, to which only elements of connection are lacking to the site of use or connection to the sources of energy and movement,
— set of the first and second indent, ready to be installed and which can only work after being mounted on a means of transport or installed in a building or in a building,
— sets of machines, of which the first, the second and the third indent, or of almost-machines, referred to in letter g), which in order to achieve the same result are arranged and commanded in order to have a solid functioning,
— set of parts or components, of which at least one mobile, connected solidly and intended for weight lifting and whose only source of energy is the direct human force"
"the quasi-machine is a set that constitutes almost a machine but which alone is not able to guarantee a well-defined application. a drive system is a quasi-machine. "
... I totally disarm myself and redo all to a nice "go to tastes, depends as you see it" :frown: in the sense that at mè these definitions do not define a good nothing, I do not understand the difference ... I ship and find this:
because if we take for good reason we say
the conveyor belt "transport" but only if connected to the current via an electrical picture and only if it is loaded by something else, means that even the conveyor belt without electrical system is “almost-machine”?
do you have the strength and patience to explain to me the general logic and also to tell me if it is right to receive and then to provide the declaration of incorporation or instead the declaration of conformity for the tape in question?
"The car is a
... but a wiper is not really aLet us make a clearing example: the wiper is a machine and can also work alone and detached from the car, but its intended use is to be installed on the car and to be connected to it and dependent on it, in this application the wiper is “almost-machine” and the complete vehicle is the “machine”.
for example his electric scootertogether equipped a drive system other than human force or direct animal
certain is mobile: Turn around all the time!composed of parts or components, of which at least one mobile
all connected inside a metal casing, with a well determined application: sweeping the glassesso the wiper is a machine No?connected with each other solidly for a well determined application.
then whatever will have a job that plans to be installed or connected or dependent on other ...but its intended use is to be installed on the car and to be connected to it and dependent on it, in this application the wiper is “almost-machine” and the complete vehicle is the “machine”.
