il disegnatore
Good evening to all,
I would like to update my current cartiglio by adding additional editable cells from tab builder.
I managed to change the template and then from the 3d model I for example added a new editing note called revision 5 with its date and signature.
I can't, however, be able to associate everything in the cartiglio.
I modified the propertise.txt file by adding fields that interest me as you can see below; I can't however perform the link operation to have the tab builder that automatically compiles rev5, datarev5 and signv5
weight
Description
revision
material
surfaces
size
model
checked
datecontrol
designed
project
Group
treatment
hardness
rev.
rev.
rev.
rev.
rev5
date
date
date
date
date 5
signv1
Signing
signv3
signv4
signv5
you should do everything from linking to property, right?
weight
Description
revision
material
surfaces
size
model
checked
datecontrol
designed
project
Group
treatment
hardness
rev.
rev.
rev.
rev.
rev5
date
date
date
date
date 5
signv1
Signing
signv3
signv4
signv5
