adminlewis
I'm not a cad user, but a simple sysadmin. I'm trying to figure out whether my users are right or not to request the purchase of particularly armored workstations. my argument is that they are not particularly hardwareized with the software in question.
the problem is as follows:
we have a folder with inside a dwg from 36 mb and various xref ... one of these is another dwg from 21 mb.. in total the folder is 91 mb.
we use autocad 2018 lt as we do not use 3d. or at least so it seems. I say so because for example the project in question has also depth in the coordinates... This infected project came to us from our client. so it is possible that it has been done either with normal autocad or with other. So the first question could be how do I know a certain design with what was created?
said this, the real fundamental question is the slowness of the project depends either on the performance of the machine. only to open the file takes at least 1 minute. I want 30 or 40 seconds every time. if I turn off and freeze the xrif the design becomes manageable.
if I leave them active is unmanageable. I made a virtual machine with 2 cpus and 2 cores each + 16 gb of ram. when I open the drawing or when I step from one table to another 1 core of 1 processor goes plan ... ok I discovered that autocad is not multithreading and the thing seems scandalous. while ram and disk remain at normal values. ie the ram autocad you eat about 4 gb ... so in total the occupied ram is 6 gb on 16 while the disk is practically inactive. Looks like the bottleneck is the processor. on the virtual machine I didn't activate the 3d as I thought it didn't serve with autocad lt. I would like to understand where the problem is. Because it's slow. Since he has plenty of resources and does not use them. I would say that the problem is the cpu.
Can someone help me understand?
