study movement
deep70
Hello everyone,
I find myself struggling with a motion study to do to understand the behavior of certain components well.. but unfortunately I don't come out.
I am not very experienced in the analysis of the movement I ask help to you therefore.
In essence it would also be simple as movement, the disk during rotation goes into contact with a lever lowering it.
I managed to create a lot of movement but tangent, that is, the lever always follows the pointer in his circular motion, while the desired result would only make it to the contact.
place the provided file that is only demonstrative precisely created to understand the cinematisms, and in addition a film obtained as I said before to tangent motion.
thanks to all in advance for the answers given and good day.
You have to use real constraints.
If there are springs you have to put them. I can't see anything from the phone, but I don't think it's very different from what I imagine. you have to use physical simulation otherwise it will be a fictitious movement. You must have the right license.
Thanks mechanicalmg, let's say that I managed to convince myself and achieve a quite satisfactory result, cinematism was quite simple with just soft and cams to be inserted in the right calibrations and criteria.
Let us say that a world would be opened behind these studies to be deepened and assimilated in the most correct way.
