version of martyr ptc
  • Thread starter Thread starter CRAZYMAD
CRAZYMAD
hi a question how can I know with which version of ptc were created solids?
I saw that there are several versions also of creo 2
from version 3 to 2 can pass the drawings? Are there any chances?
thanks to all
that I know you cannot know with which version a part/axieme/table has been created.
all creo 2 datacodes are compatible with each other. If I open a m020 with a m110 and vice versa I have no problem. If I open a part saved in creo 2 with creo 3 I have no problem. instead I can't open a part saved in creo 3 with creo 2.
to see the version with which a creo file was saved just open it with a editor (not the classic notepad, better a notepad++ or ultraedit that format the text correctly) and you will see the line 12 version and build:
Code:
#creo  tm  3.0  (c) 2017 by ptc inc.  all rights reserved. m120
with previous versions was a little different, you had to scroll down more (e.g. row 200)
e.g. with wildfire4:
Code:
#pro/engineer  tm  wildfire 4.0  (c) 2016 by parametric technology corporation  all rights reserved. m220
but also here is version and build
each version (e.g. 1.0 or 2.0 or 3.0 or 4.0) can only save in its own version and only open its own obviously and precedents.
then, within the same version, the patches todayornamenti (e.g. for version 3.0 there are updates from m00 to m120) but do not affect the opening, that is the only version.
Say hi.
