does not export all views in dwg/dxf
  • Thread starter Thread starter ale1190
ale1190
I happen every now and then, at the table of totals, to fail to export in dwg or dxf.
At first I attributed the fault to downloaded commercial components, which were "defective". actually other times, deleting or reloading these components, the thing was resolved.
but not this time. I came to clear all the components to see to find what gave the problem, but nothing. :36_1_4:
This is the table, very simplified, which I have left:Immagine tavola.webpapparently no problem. sin that when I go export to dwg or dxf, the result is this:DWG sbagliato.webpthe a-a section has disappeared, but its details are seen.. :36_1_25:
attached a zip with inside the files we say "corrotti".View attachment NON ESPORTA TUTTE LE VISTE.7zHas anyone ever happened anything like that? Can you help me?
first put the solid version in the profile.
said this to me it exportes without problems, but at the rescue comes the message of update of the image. before doing the dwg do an update (ctrl+q) and then saveImmagine.webp
said this to me it exportes without problems, but at the rescue comes the message of update of the image. before doing the dwg do an update (ctrl+q) and then saveView attachment 48424
updated version :cool:
As far as the problem is concerned, I haven't solved it.
First of all I don't get the message you say, it can also be that it was clicked long ago "do not display this message".
Can you tell me how to restore these messages?
In any case I tried to make a ctrl+q as you said, but saving the dwg I always have the same identical result of half hidden views.
:36_1_4::36_1_4:
tried to export with s.w. 2017 export without problems. I don't have autocad but drafsight and everything works fine.
Cattura.webpthis screen options I usually use and problems never had.
View attachment 48612this screen options I usually use and problems never had.
I stop at sw16.. I also use drafsight and have your own identical settings. And nothing, I can't export properly. .
It's a desperate case. :36_1_4:
Are all views in high quality? Usually this problem manifests with views in quality draft.
Yes.. all in high quality. We say that when I happen it is the first thing I control, but almost always nothing changes me.
Although in reality, in general, not all the drawings I carry have seen in high quality, but it never bothers me. only in exceptional cases like this I have seemingly mysterious problems. :frown:
